L76 6.0 questions
I fell into a rect port fast 102... How much power could I make out of this motor with a set of ls3 heads, 235/243 .620 cam. And a fast 102?
I know nothing about the "l76" design.. The 6.0 bottom with ls3 top end.
I'm trying to get as close to 500 rwhp as possible . I know cam only ls3's make close to 500. So would this BO doable with stock ls3 heads? It would I need ported ls3 heads v
Thanks
If you decide to do any work to the heads, I would concentrate on the exhaust ports and combustion chambers. I wouldn't touch the intake ports.
Have the heads ported on both sides as it will help airspeed if done right, but don't go more than 5-7cc bigger on the intake, shave the heads 0.020" and run a 0.040" gasket. That should get you to ~ 11.3:1. With that intake and a good exhaust that should get you to 500 rwhp and still maintain drive ability and low end.
Jason
