Cam Change Q.
Old Aug 8, 2016 | 03:52 AM
03EBZ06's Avatar
Default Cam Change Q.
LS3 block Mast Heads and link bar solid lifters. Is it possible to change the cam w/the heads on?
Old Aug 10, 2016 | 03:15 PM
blackonblacksls's Avatar
Yes. Even when I had some of the link bar lifters fall, I grabbed them with a magnet and pulled them back up to clear the cam
Old Aug 19, 2016 | 01:16 PM
05GTO6.0's Avatar
Yes it is possible to change the cam with the heads on, just remove the rocker arms and pushrods first. I would recommend putting some wooden dowels in the two holes above the cam to avoid having the lifters fall down
