Question about LS3 heads on a 6.0L block
When running the LS3 heads on an LS2 short block, is it worth it/possible to mill the heads to reduce the chamber volume to match the compression ratio on the factory LS2 motor? To the best of my knowledge, the stock LS3 heads have a chamber volume of 68 cc which results in a 10.7:1 compression ratio on the LS3 engine while the 243/799 heads that come on the factory LS2 have a chamber volume of 64 cc resulting in a 10.9:1 compression ratio.
I guess what it boils down to is, is it worth worrying about the difference in chamber volume and an associated loss of compression ratio, or do you just bolt the LS3 heads to the LS2 short block and the gains from the increased flow outweigh any minimal loss of power due to a decrease in compression ratio??
Thanks for the help guys....still learning as I go
I recently flycut our LS3 pistons .100" and had 0.075" machined off of the heads, the difference in idle quality and throttle response is night and day!
