Cam help please??
I don't know much about cams but I do know they make great power and sound wicked. This is my daily driver so I don't want my idle too choppy. But I want a decent size cam. With all of my mods what would you all suggest I get size wise? And I know other people replace things too when they do a cam swap. What else should I get replaced while I'm swiping the cam to save my money? And what company? I was planning on going Texas speed or comp cams. Any help would be appreciated!
You will want/need new valve springs, new pushrods, and Martin will help you with all of it. He is a sponsor on this site and he will take good care of you.
Not to mention, we grind the best cams in the industry...not because we say so, but because the testing says so.
No Squealing, and peeling lobes to worry about. The machine we use to cut them is state of the art and gives us the ability to make some awesome stuff. When compared to some of the manufacturers, our cams just flat out make more power because we are able to cut a re-entry. The quality of our cams are second to none, it is easy to see when you hold our cam compared to the competitors.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
