LS3 in early bronco cam advice
ASA cam: 226/236 .525/.525 110+4
Hot cam: 218/228 .525/.525 112+3
Out of those two choices, I would think the Hot-cam would make for a better daily driver, depending on the gears and stall used. Granted, I prefer small cams, so I may be biased. That is why I said these decisions are best left to the professionals.
What Transmission do you have?
If an auto.....what stall TC do you plan to run?
What rear gear are you looking to run?
What diameter tire are you using?
Choosing the right cam isn't JUST about the engine or the projected use.....it's also about the vehicle.
KW
http://www.lingenfelter.com/product/...l#.V8yuAxGwUUg
If you were looking to get closer to max power but still have relatively good drivability, then look at something along the lines of the Lingenfelter GT1-1 cam. This cam will have a noticeable lope at idle, will have good low RPM power and will pull strong all the way up to the limits of the stock intake (about 6000 to 6200 RPMs)....all with very minimal cam surge. You might want to consider bumping up to about a 2800 to 3200 stall torque converter with this cam. This is the cam in my 4300 LB, 95 Impala.....like it a lot!
http://www.lingenfelter.com/product/L210075297.html
All that being said, I'd choose a cam with less than 9* of valve overlap. This may hurt top end power a bit, but it'll definitely make for a MUCH better street ride.
Best of luck!
KW
