ls6 rod torque?
Old Sep 2, 2016 | 04:25 PM
Kingdong's Avatar
Default ls6 rod torque?
Grrrrr... I hate this pos angle torque tool .I feel like I'm about to pull the threads . 15 ft.lb. Then 85 degree twist. Does not feel right. Anyone ever figure what torque this comes out to . Thanks.
Old Sep 3, 2016 | 08:21 PM
slogo's Avatar
You must be doing something wrong, angle gauge very easy to operate.
I wouldn't use a torque wrench, there is a reason they use the angle gauge.
To me thats a part I don't want to just be good enough. My .02, good luck.
Old Sep 3, 2016 | 08:22 PM
140K_GXP's Avatar
If you are using ARP bolts - 45 ft-lb using their lube(no angle torque)
If stock GM bolts - 15 ft-lb then 60 degree angle torque.
Make sure to use oil or the ARP lube on the bolts.
