rocker arm question
the diameter of your screw in studs (3/8)?(7/16) are to big to slide these rockers on.
And then I would wonder if the different valve angle would play a part in all this.
You might can get them to work, but it is not going to be just a bolt on. Personally I would just use an aftermarket 1.6 rocker that is designed for your heads. Good Luck
I have seen a couple applications where the smaller 8mm valves were used in a SBC head, along with beehive springs, keepers, and retainers from an LS.
