Blown hesd gasket ls7
Old Oct 17, 2016 | 06:39 PM
bottledgto's Avatar
Anyone ever blow a gasket like this ?
Old Oct 17, 2016 | 08:53 PM
DietCoke's Avatar
on 3 different cylinders? Something wasnt right there...
Old Oct 17, 2016 | 09:12 PM
bottledgto's Avatar
At first I thought the head wasn't torqued correctly so I had the heads resurfaced and put new head gaskets .. well now it's doing the exact same thing again but on 2 cylinders ?? I'm frustrated being its a c6 z06 and it's not an easy task to be taking apart .. has arp head bolts 13:1 compression a long with a 100 shot and e85 ???? I'm thinking head studs next
Old Oct 17, 2016 | 10:31 PM
96 Comp T/A's Avatar
What gaskets are you using? MLS? Copper?
Old Oct 17, 2016 | 10:34 PM
bottledgto's Avatar
Gm mls ls7 gaskets
Old Oct 17, 2016 | 10:55 PM
Have you checked the block with a quality long straight edge and feeler gauges or maybe a flash light? Any signs of detonation on the pistons or chambers? It's tough to tell from the pics, but it looks like from your pics it's burning clean.
Old Oct 17, 2016 | 11:25 PM
bottledgto's Avatar
Not yet bud but I'm gonna pull the heads off again so I'll do just that I'm pulling my heist out as to why though , car had never overheated and is low mileage factory ls7 short block
Old Oct 17, 2016 | 11:43 PM
I've never had hands on a factory LS7 block. Do the threads for the lower head bolts come right to the top of the hole, or are they recessed down a ways? Possibly if bolts were over torqued, it could have uplifted the block surface in those spots. It's worth looking into when you get that straight edge on there.
Old Oct 18, 2016 | 04:02 AM
American Heritage's Avatar
Interesting photo even to us... we do more LS7's than most shops in the country
As noted above strait edge on the block and report back.
