LS2 with l92 heads
I know that these heads run better with a small cam, I plan on getting Pat G to spec one out for me. This is my first time actually modifying an engine. I'm not sure on how much I should shave the heads or which valve spring set to go with?
My engine is a stock LS2/t56 out of an 06 gto that will be going into my 71 Chevelle.
It made 477rwhp and ran a best of 11.12 @ 121.06. If that helps you!
Ought to be real interesting!!
BTW.....what you car's weight/gears/transmission?
Thx!
KW
