GM LSX Block Main Cap Torque specs please!
Old Nov 12, 2016 | 03:56 PM
yoshgixxer's Avatar
Default GM LSX Block Main Cap Torque specs please!
I need to know torque specs for the GM bow tie 6 bolt block billet main caps with ARP studs?
Thanks!!
Old Nov 13, 2016 | 10:26 AM
KCS's Avatar
KCS
Moderator
It's going to be in the ARP instructions. IIRC, it's like 60ft-lbs for the inner studs, 50ft-lbs on the outer studs, and 25ft-lbs on the side bolts. I suggest you look it up on ARP's website just to be sure.
Old Nov 13, 2016 | 05:08 PM
yoshgixxer's Avatar
That does sound right, just wanted to make sure there was nothing different wth these LSX blocks vs standard LS block
Old Nov 15, 2016 | 01:37 PM
SAPPER's Avatar
If you have #134-5802, here's the ARP instructions
http://arpinstructions.com/instructions/134-5802.pdf
and for part#234-5608
http://arpinstructions.com/instructions/234-5608.pdf
