Is that normal for a 27K LS2 engine?
Old Dec 3, 2016 | 07:52 AM
Kamaro's Avatar
Default Is that normal for a 27K LS2 engine?
I'm in a process of swapping heads and cam into my 2006 LS2, it has 27K miles and it never driven so hard, I found the timing chain is a little sloppy, these LS2 timing chains aren't they suppose to be tight and strong?, or is this normal for a stock chain?
Oh, one more question, is it OK to add a LS3 timing chain tensioner? I got a brand new one laying around.
here is a short video of the chain :
Old Dec 3, 2016 | 09:18 AM
A.R. Shale Targa's Avatar
Most people from gen one experience think they need to be tight. Aluminum blocks "grow" a lot so room temp slop means little to operating temp when the cam tunnel moves north
The tensioner is a good idea if you have it
Old Dec 3, 2016 | 02:13 PM
homemade87's Avatar
My 2006 tbss ls2 engine was the same way . I put a new chain on it and it was still like that .
Old Dec 3, 2016 | 03:56 PM
truckdoug's Avatar
too tight just wears the bearings out
Old Dec 3, 2016 | 10:59 PM
Kamaro's Avatar
I will be installing a new cam with .629 lift, will the stock LS2 chain be OK with it?
Old Dec 4, 2016 | 10:04 AM
MuhThugga's Avatar
The LS2 chain is a decent piece and you will not have any problems with it. If you want to upgrade, go with the IWIS chain. It is a really nice piece and is only like $80.
Keep the LS2 chain dampener.
Old Dec 4, 2016 | 10:05 AM
Plenty fine
I used a Pro Gear by Avon products
Single row Decent piece for like $80
