LS7 Cam, Spring & Rocker Recommendations
So here's the challenge:
Goal is 600-640whp, predictable torque throughout, 7200-7500rpm redline
less than $3000 (not sure how realistic this is yet)
simple swap if possible, done with heads in place
Engine as it sits:
GMPP LS7 dry sump crate engine w/ control kit
FAST or Airforce 102mm intake, w/ cold air feed
1 3/4" mid length headers into 3" cat back, straight through
I want to swap the cam and related parts before the engine goes into the car, because once it's in you can't reach it without pulling the motor out. Once I've gotten use to the power I want to upgrade the heads to MAST or RHS cnc'd heads and a little more power. I don't want to do that initially so I can keep build costs down.
Good for you that your car is ultra light
I would call either Geoff Skinner at EPS or Kip Fabre at Cam Motion for an upgrade kit that can both make more power but not beat the hell out of the valves and guides
A low lash lash solid roller might just be the hot ticket for you
