Valve reliefs?
Old Dec 27, 2016 | 04:19 AM
Justin Adams's Avatar
Default Valve reliefs?
Doing a 6.0 with a set of 241 heads with 15 thousands taken off them, a stage 4 truck cam, and whatever the stock thickness is on the head gasket. Do I need to be worried about valve clearance? Didn't know if I should get a set of regular flatops or if I need a set with valve reliefs. Haven't had a chance to ask my motor guy. Thanks for any input.
Old Dec 27, 2016 | 04:38 AM
Dyno Junkie's Avatar
Don't know the cam you are using, so unsure of clearance issues.
But why are you using 241 heads on a 364?
Old Dec 27, 2016 | 10:11 PM
224/230 .553/.547 111+2
And because they're close enough to beinf the same as the 243 for what I want and for what I paid for them.
Old Dec 29, 2016 | 02:06 PM
CAMSTER's Avatar
No piston to valve interference with that cam but you can always turn the engine by hand if it turns free you are good.
I would no worry I done .232 / .620 no problem
Old Dec 29, 2016 | 02:08 PM
WE TODD DID's Avatar
LOL what?
Old Dec 31, 2016 | 05:45 PM
03sierraslt's Avatar
Moderator
Lsa plays a major role in valve events so that by itself doesn't mean much.
Old Dec 31, 2016 | 10:15 PM
LLLosingit's Avatar
I sure hope you're being sarcastic
Old Jan 1, 2017 | 03:34 AM
Kamaro's Avatar
I would use a small piece of clay on the piston and check the valves impression. This is the best and most accurate way to be sure, plus its very easy to implement.
