Help with LS2 Stroker Build
Old Dec 29, 2016 | 09:00 AM
pantera_efi's Avatar
Default MY 60-2 (58x)
Hi, there is another item, the Spark Accuracy.
This item effects maximum safe C.R.
The LS-2 OEM uses a 24xe TW.
The newer LS-3/92/7's use a 58x (60-2) with a + .5 C.R. increase is some cases. (2006+ GM OEM)
What is the tooth count on your crankshaft TW ?
Lance
Old Dec 29, 2016 | 10:13 AM
thunder57's Avatar
Going with a 24x RW to go with my LS1 PCM
Old Dec 29, 2016 | 10:42 AM
thunder57's Avatar
What would be the benefit to this?
Originally Posted by A.R. Shale Targa
nicely designed slug for sure I would touch that atenuator(intake relief edge) groove area with a cartridge roll and call it good
Old Dec 29, 2016 | 12:13 PM
1989GTA's Avatar
Some times a sharp point can be a source for pre-ignition. Best to lightly sand any sharp ridges.
