Need help identifying a cam
Old Feb 4, 2017 | 02:33 AM
05cts-vnewb's Avatar
Default Need help identifying a cam
If any of you guys can help me ID what engine this cam is from that would be great. I've searched for quite some time but can't find another LS cam with these markings. Thanks
Old Feb 4, 2017 | 08:03 AM
KCS's Avatar
KCS
Moderator
Stock GM LS7. Stock camshafts had that barcode at the bottom. The bottom row of numbers is the last 4 digits in the part number:
https://m.summitracing.com/parts/nal-12638426
Old Feb 4, 2017 | 12:09 PM
Thanks, was thinking it was either ls7 or ls9 but wasn't sure.
Old Feb 4, 2017 | 05:33 PM
07NBSChevy's Avatar
Not to steal the thread or anything but I was wondering the same on my stock cam. I could not find any info even using the last 4 numbers. Its a Gen4 LMG 5.3. I would like to know the specs on it.
Old Mar 21, 2017 | 01:28 AM
68shortwide's Avatar
Quick Google search of "3207 GM cam" brings up a few threads on it being a L33 cam. Hope it helps.
Old Mar 21, 2017 | 09:42 PM
07NBSChevy's Avatar
L33, Part #12583623, 193/193 .479/.479 116+2, used in 2005-2007 Gen3 5.3 Aluminum Blocks
LMG, Part #12625436 (12593207), 193/193 .480/.480 116+2, Used in 2007.5-2013 Gen4 AFM 5.3. Often confused for L33 Cams
