24x in a ls3
https://www.goodson.com/Reluctor-Rin...allation-Tool/
If this is likely a one-time deal, bring your crank to a machine shop that is familiar with LS engines and they should be able to swap it for you for about $100 I think. Just make sure they truly are LS knowledgeable. It's not a complicated job but one that must be done precisely or you'll be chasing your tail forever with a bad crank signal.
1. Fit the Black Crank Sensor
2. Weld "stitch" the 24xe TW onto the crankshaft
3. Reverse the two outside wires in the CAS connector
Lance
There are a few other things youll need as well.
Email me if you want a list of parts and pricing!
Rpmspeedtech@gmail.com
We are doing a complete turnkey for a customer with an 00 fbody right now actually.
