Crower Lifters
Old Mar 26, 2017 | 07:20 PM
jobe_ls1's Avatar
Default Crower Lifters
Anyone run the Crower solid roller lifters? Im trying to figure out which length I need. Looks like they have a standard length and .3" longer for small bs cams. Pretty sure I can use the standard length as the lobe I'm using is a .650 lift cam motion llsr lobe and the 454 LSXr uses the one in the pic which looks like the standard length.
Old Mar 27, 2017 | 07:11 PM
jobe_ls1's Avatar
Talked to crower and said I need the tall. Also confirmed that 66278TH is the same lifter GM uses for the LSXr builds.
