Will this cam work in my stock ls2?
Old Apr 8, 2017 | 07:32 PM
GrnGoblin's Avatar
Default Will this cam work in my stock ls2?
233/248 | .627”/.612” | LSA113+5
Thanks realized i ordered a ls3 cam and not a ls2.
Old Apr 8, 2017 | 07:54 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Work? Phyisically fit? Probably,
It will drive like crap in a stock ls2!
+6-8* exhaust split much more ideal.
15* Split would work well with 300 shot N2O.
Old Apr 8, 2017 | 08:11 PM
GrnGoblin's Avatar
I do plan on spraying it as well. Might be something i try this season and swap it out over next winter. Cams already in the motor now and realized its not for a ls2
Old Apr 9, 2017 | 05:27 AM
Dyno Junkie's Avatar
I fitted CompCam 235* 243* .621" .624" 113 to a stock LS2.
Worked surprisingly well.
Old Apr 9, 2017 | 09:27 AM
joyridin''s Avatar
It will work fine. Probably a little low on low-end torque, but when the cam kicks in, hold on tight!
Old Apr 9, 2017 | 06:13 PM
Exactly!
Old Apr 9, 2017 | 09:02 PM
GrnGoblin's Avatar
Thanks guys i appreciate it. Gunna give it a whirl
Old Apr 10, 2017 | 02:06 PM
+8* exhaust split is ideal for med/large cam with a stock LS2 head/engine IMO.
+15* exhaust for the same combo a completely different
animal, probably very soggy low and mid-range, bleeding
of so much cylinder pressure until you get to 4000-4500
RPM. If it were me I would return/exchange if possible,
sell if not, its a lot of time and expense to put in a cam
so far from optimal.
My .02, worth what you paid for it lol.
good luck.
Old Apr 10, 2017 | 02:10 PM
Tuskyz28's Avatar
I agree with Navyblue... cam would be okay if you was running LS3 heads and wanted max effort out the combo.
Old Apr 10, 2017 | 07:13 PM
good luck.
Agreed it's not the best cam available, but it suited the owners requirement to "sound tough".
On a side note it is surprisingly driveable for a manual.
Prior to the cam the best the car had run at the track was 13.9.
After the cam it went 12.53 on street tyres and 12.20 on drag radials.
Old Apr 10, 2017 | 09:31 PM
On a site note it is surprisingly driveable for a manual.
Your cam is fine, a "little" big perhaps, but still designed for LS2.
OPs Cam is large for stock LS3.
