New LS3 4.00 stroker build?
I remember reading an old magazine article, they said the LS3 cylinders were undercut making this possible.
This information seems to conflict with other data I have read.
Thank you for Yor help.
My crankshaft/rods are manufactured in the same China Plant.
I have ONLY used 2.1" rod/cranks.
I can send pictures ?
The notch is for the bolt, about the size of a "dime" to be sure.
MY METHOD is the fit the crank with OLD bearings, then the rod with old bearings, one only with piston NO rings.
Then install this into each bore, slide to the crank fillet, MARK with a Felt Marker.
I "grind" each one separately, check for clearance, then on to the next bore.
Use an "old piston if possible, if NOT CLEAN after each grind/bore relocation.
Lance
Also make sure to install your windage tray and pickup tube/oil pump to make sure you do not need to space them as well.
