High Comp heads on 416?
Old Apr 24, 2017 | 06:42 AM
Dyno Junkie's Avatar
Default High Comp heads on 416?
Unfortunately our flycut LS3 decided to break a ring land this week.
Simply trying to see what is reusable if I go down the path of a 4" stroke.
Heads milled .075"
Rick Crawford AirRam inlet manifold
Comp Cams 231 239 .617" .624" 113 cam
Old Apr 24, 2017 | 07:32 AM
MuhThugga's Avatar
You can always get a piston with enough dish to bring the compression to where you need it.
Old Apr 25, 2017 | 11:05 AM
KW Baraka's Avatar
And if you get dished pistons, that much less of a risk of PTV clearance issues.
Basically, I'd advise reusing the heads/intake. What cam to use will depend on the totality of your build.
KW
