what cam for ls2 bottom with ls3 heads.?
something similar to the ASA cam 226/236 would work pretty well
without fly cutting for the bigger valves, you usually can't fit much more than a 230-232 sized intake lobe
If you wanna email us, we can get you everything you need including harnesses, cam, springs, etc and get you taken care of!
Rpmspeedtech@gmail.com
Also, the car is FACTORY quiet. Barely, and I mean BARELY has any chop at all. Other than headers the car has factory exhaust and all factory resonators/mufflers.
-Russ
http://vengeanceracing.net/vengeance...rder-form.html
Its better to give all the facts like that instead of saying "dont flycutt" with no other info. it can be pretty misleading.
Just looking at those specs, honestly i hope you arent serious. Overkill is a light term for that.
Normally i like to flycut with no head gasket to give that extra clearance, but i also keep that in mind when doing the deed. A heaf gasket is roughly .050 to round easily so youd have .150 clearance at least.
Your "roll race" call :
Fit Felpro 1041 Head Gasket with China studs
Fit camshaft 236/242 .560"/.535" with a L/C of 116* at Split Overlap
Fit Yellow of Blue springs
Fit a 2010 Camaro Oil Pump
Fit a single Timing Chain with Billet Gears
These items are in stock if you what my help ?
Lance
And a 2010 camaro oil pump is the same as a 2003 5.3l oil pump.
I dont want to get into a vendor war, but there is a difference in recommending cheap parts (also blatant lower quality chinese parts) and recommending good quality inexpensive parts.
We always like to recommend a single roller for most builds due to clearance issues. Normally itll be a melling 10295 and a JP perf single row billet or Rollmaster single row billet, or cloyes single row hd setup.
1. GM does NOT service ANY part older than 10 years, this is WHY I state 2010 OP AND it IS the BEST part at the lowest COST.
2. The MAIN REASON I fit a head stud that will "grow" as does the head "grows" is to keep constant TORQUE.
When a head stud does NOT GROW, something will "give" most often it is the gasket.
This can cause the problem of a "blown" HG.
THIS art was taught to me BY Mike Costin when he created the BDA head for the Kent Ford block.
THUS who should the users here trust ? COSWORTH ? OR ????
AS for the other items you state, most, if not ALL of your state ARE made "off shore".
EXAMPLE : Cloyes BUYS Timing Chains for resale under their name.
Lance
You are really digging your own hole here and its not worth the extra effort to rip apart what you've said but ill say a few things.
7 years isnt 10 years. Gm still has many parts for ls1s. Gm doesnt make alot of their parts either. They buy em and put their name on them. Cloyes doesnt make chains, but they will sure tell you whom they get them from, either Rolon oe Romac or Iwis etc There are only a few places in the world that make quality chains.
All of what you are saying is a mixture of old news and bad ideas.
Im guessing the reason most like chinese head studs are they are cheap. Ive also seen more failures in a few months with them than any other stud out there. From threads not made right to stripping them while putting a nut ON them to pulling the threads off the stud upon torque procedure and them snapping off. We have the opportunity to sell them also, but refuse. A $40 stud kit isnt only too good to be true, its an insult to engine builders and customers. Im curious about the factual difference, so stay tuned. Im going to have some interesting info on them soon.
Lance
