Pontiac G8 LS3???
Old May 4, 2017 | 10:11 PM
Mike1955f100's Avatar
Default Pontiac G8 LS3???
Bought a LS3 with 821 heads, engine serial # 29L206818. Can anyone tell me if it's actually a G8 GXP engine from the serial number?
Old May 4, 2017 | 10:26 PM
big hammer's Avatar
IIRC the G8 6.0 was an L76 that had l92 style heads. Could be what you're seeing
Old May 4, 2017 | 11:52 PM
KW Baraka's Avatar
The G8 GTP came with the LS3 engine.
The question here is whether GM stamped the LS3 block with a partial part number and whther the OP can find that part number on the block.
For instance, the Gen-2 SBC engine block (LT1 and LT4) was stamped with the number "327" on the block. It was the best way to determine if in fact the block was a LT1 or if it was the 'baby-LT1'.....the 4.3L L99 engine that came in a lot of Caprices from 1994-1996.
So.....does the LS3 block have any specific group of numbers/letters stamped onto it?
KW
Old May 5, 2017 | 04:50 PM
KW
I'll take a better look next week.
Old May 5, 2017 | 07:40 PM
1929chev's Avatar
according to your VIN. You have a L76 motor.
LS2
Old May 5, 2017 | 07:42 PM
1929chev's Avatar
G8 GT.
Branded title February of 2012.
Old May 5, 2017 | 09:17 PM
LS2
Is their a website that I can go to to research the engine serial number? Did the ls2 come with 821 heads?
Old May 6, 2017 | 05:42 PM
cookseyb's Avatar
From my limited research most LS2 's came with 243/799 heads..
Old May 6, 2017 | 07:17 PM
Thanks.
Old May 7, 2017 | 11:28 AM
Jimbo1367's Avatar
The L76 isn't a LS2. While its 6.oL, it has the L92 heads. Look at the front drivers side of the block for the casting saying either 6.oL or 6.2L
Old May 7, 2017 | 02:30 PM
Thank you, should I be able to see this easily? I've not put the body on the frame yet but have front dress up kit on the engine?
Old May 7, 2017 | 05:55 PM
cookseyb's Avatar
Is the G8 a Holden like the GTO?
Old May 7, 2017 | 06:02 PM
handyandy496's Avatar
No
Old May 7, 2017 | 06:15 PM
g8 gt=6.0 g8 gxp=6.2 detuned Corvette engine.
Old May 7, 2017 | 06:21 PM
https://ls1tech.com/forums/attachmen...1&d=1494199246
Old May 7, 2017 | 10:00 PM
KW Baraka's Avatar
The G8 is a left-hand drive Holden Commodore.....
KW
