LC9 Questions
The cam plate has the "gasket" seemingly molded into it, just reuse it, or buy a new plate?
Do I need different pushrods? I bought a set of
Summit Racing SUM-G6400-LS - Summit Racing® Pushrods
Pushrods, Steel, Heat-Treated, 5/16 in. Diameter, 7.395 in. Length, Chevy, LS, Set of 16
Will these work?
Thanks, Frank
You dont need the grooves.
You will prob need springs.
You prob wont need pushrods.
If you are going for afm delete youll need to replace quite a bit, what do you have so far?
Brand new, the orange seal on the cam retainer plate protrudes a bit. They aren't expensive, so if the orange seal feels flat, I replace it. Other have gotten away with a light coat of RTV and reusing it though.
All Non DOD parts (I hope)
I'm thinking I'll get a new one to be safe
Thanks guys
