LS3 Swap Questions
So i pretty much have everything I need and after doing some searching I am having problems finding out what people are using for the mass air sensor. Also, I know I will need a legit tune but will the car start and at least idle with the tune I have or will I need a rough tune to at least get it to start?
So between maf sensor and tune what do you guys recommend.
Oh also, im going with a 228/240 113 eps cam, ls3 intake, stock compression, full exhaust and thats all the particulars i can think of.
Thanks
Yea i should have mentioned that it is indeed going back in the SS with factory wiring etc.
Do you have a link or P/N for the truck maf? Thats also an 85mm unit correct?
The maf kit with adp harness is here
As far as the first start is concerned, will the tune thats been loaded in be close enough to get it started and relearn an idle or do i need a rough tune that will be a go between until i get it to a shop?
You will want to reuse your map sensor as the new ls3 sensors are scaled diff. Normally youll just find an o ring or 2 that fit over the stock sensor grommet and fit snug in the map sensor bore from your local parts store.
The tune in it could make it start but i would not run it long.
Did you swap to a 1x timing set also?
