lq4 block with ls3 heads or stock
Old Jul 8, 2017 | 09:08 PM
jaws57's Avatar
Default lq4 block with ls3 heads or stock
HI Guys
I"ve been read and searching through the forums. I"m new the engine world, Found out that i might be better to use the stock heads on my lq4 than buying a set of ls3 heads for 600 bucks.
For information the lq4 is going into a 1956 chevy truck with 1" 7/8 long tube headers with a 4l80e tranny and 3.42 rear end. I"m hoping for 450 hp and have its as a Daily driver. I"m thinking of putting a t56 behind the truck when i find some more money.. but for now i want to drive the truck and enjoy it..
Thoughts or links to other builds or idea is all welcomed.
Old Jul 8, 2017 | 10:04 PM
You don't need LS3 heads for 450HP. Besides the heads, you would need a whole new intake system as the ports are different between the two types of heads, so you would be out a lot more than $600. What you might want to do is have your heads milled a bit for more compression and ported for a bit more breathing. That and a mild cam will have you at 450HP in no time. For more info on the above mods call either WS6 Store or Texas Speed and Performance. You will get the help you need and good prices in either place. Both are sponsors here so look around the site and you will find contact info on both of them.
