Engine stalling
Old Jul 22, 2017 | 03:18 PM
2001CSS's Avatar
Default Engine stalling
Today I took my 2001 camaro ss for a ride and when I got on the highway and did a quick pull from 1st to 4th when I came to a stop at the light with the clutch in the car kept stalling out. When I got home I checked the dipstick and noticed it was really hot and a little smoke was coming out the tube. Was wondering what that's about.
Old Jul 22, 2017 | 04:48 PM
Crf450r420's Avatar
Smoke could mean more blow by and that happens when you lose a hole, which will also usually cause it to not idle. See if you are firing on all 8, check for spark and do a compression check is the usual start area.
Old Jul 22, 2017 | 07:13 PM
2001CSS's Avatar
Ok thanks for the help
