BTR3 and Heads Question
Old Jul 23, 2017 | 05:14 PM
jandylee070601's Avatar
Default BTR3 and Heads Question
Have an 05 LS2 GTO, just installed the BTR 3 cam, LS7 Lifters, and Thompson Motorsport CNC 243 Heads with Stainless valves, .660 BTR valve springs with the 0.041 Gaskets. Do I need to change push rods? TIA
Old Jul 23, 2017 | 05:43 PM
I would at least measure for correct length, especially if the base circle is different &/or if you milled the heads. You are working with a bunch of unknowns, so pushrod length is an unknown too.
Old Jul 24, 2017 | 06:58 PM
Default cam
From what I know the heads was not milled. But I can email and ask
Old Jul 24, 2017 | 09:58 PM
Whether they are milled or not you STILL should verify pushrod length. Not that hard to do, takes a bit of time, but something that should be done right!
