LSA pistons for a 4.080 over-bore
1- Whats the dish size of the factory pistons? I could not find any info about that.
2- Can I get away from balancing the whole assembly by installing pistons of the same weight as the old ones? balancing charge is very expensive where I live.
3- Who sells a good set of factory specs oversized pistons?
My method, "thin wall sleeve" the bad cylinder.
Install RaceTech 4.06? Forged pistons, a lower weight piston with new Steel Rings.
THUS NO Re-balance needed.
I can supply the piston & rings ?
Lance
PLEASE take the time to provide the weight of the piston, pin (.945" ?), rings. (one assembly)
The NEW Forged Piston, Pin, Rings can be equal to OR a little less in weight.
This case will SAVE $$$.
The bore, 103.5=4.075" a more common ring size.
Lance
