Gen 4 knock sensors fbody
Old Sep 9, 2017 | 06:02 PM
SVTFAN09's Avatar
Default Gen 4 knock sensors fbody
I just acquired a gen 4 block to go into my 2002 Camaro I've purchased a Dod delete kit and Afm kit as well. The car will be running the stock Camaro harness and what not, upon installing this in the car I've noticed the block has 2 knocks sensors on the right and left outer side of the block , do I cap these off or what
Old Sep 9, 2017 | 06:48 PM
MY_2K_Z's Avatar
No you will have to tap them for your knock sensors and get an extension harness for them.
Old Sep 9, 2017 | 06:56 PM
KCS's Avatar
KCS
Moderator
It helps to do a little research....
UPDATED- L92/L76/LS3 Engine Into 99-02 F-Body
Old Sep 10, 2017 | 05:34 PM
SVTFAN09's Avatar
Thanks a lot boss well I just ordered knock sensors for a ls1 along with the knock sensor extension harness,they should be here by Wednesday, I'm still on the fence about the cam and map sensor harness extensions. I'm running the stock ls1 map
