Need help from the pros! bottom end mishap with torque procedure
i used the 15 lbs to 81 degrees sequence but i used a angle finder on a ruler and my eye ball to find the 81 degrees. Bootleg i know. Kicking my self now. am i over thinking this process or do you all recommend i take the short block apart get the appropriate angle finder and do it again. Everything else should be dialed side bolts are 18 lbs rods are 15 then final sequence 75. so its just the main bolts that i could have done wrong. Everything is new and prepped by a reputable machine shop. I hope all is well guys!
