Posssible to mid sleeve the LY6?
i have my iron large bore bowtie race block set up for splayed valve heads still and that's been sleeved in the rear cilinders and it's still going strong after a few blow ups.
Your talking let me Show you how I think.
Dear Paco
On a 4.400" bore spread, 4.200" is the max. possible bore size with either wet or dry sleeves. The only way to go to 4.250" on a 4.400" bore spread would be to machine the block to just under that size and have the bores plated with nikasil. Not sure how long it would last or what you would use for head gaskets at that bore size.
MID $2,675, Seal Tight dry $1,975. Max. bore on the dry is 4.185".
Steve
race-engine-development@***.net wrote:
The iron block is considerably thinner than the aluminum and does break through into the timing cover area as shown in the photos. That area has to be epoxied up.
Would I recommending doing this now, NO. I can sell you an iron LS Next block for at least a grand less. That casting is much thicker and stronger than the factory iron blocks and has priority main oiling if that matters for your application.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
