Quick Questions re ARP Head Studs on LS7
Old Oct 7, 2017 | 01:31 PM
fallen's Avatar
From: Upper West Side, New York City/Very Downtown, Houston
Default Quick Questions re ARP Head Studs on LS7
Thanks in advance for putting up with my questions:
1. Do I need to use sealant where the stud (ARP) screws into the LS7 block? (I think the hole is blind, just double checking)
2. I am using TFS 235s on my ls7. ARP kit says torque the ten large heads studs to 80 ft lbs on last pass. Correct or is anyone using a different final torque spec on last pass?
Cheers and again thank you.
Old Oct 7, 2017 | 02:46 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Blind holes but make sure to blow them out first very well. No need for sealant really.
Use Arp specs. You can find em on their website of you dont have it.
Old Oct 7, 2017 | 11:49 PM
fallen's Avatar
Much thanks!
Old Oct 8, 2017 | 08:41 AM
Double06's Avatar
If you have time, after you torque them the first time, come back the next day and double check the 80 pounds again. I use the ARP torque/assembly lube which is good stuff. Same goes true with the manifold bolts recheck them the next day the plastic manifold and rubber gasket can settle a little.
