LS2 teardown question.
If your engine has some miles on it, pull the rod/piston and check the big end size without the bearing in it and see if it's still round. Then check the bearing clearance with the crankshaft.
It's out now, better to be safe than sorry and have to repeat the job of pulling it out.
Cole
Usually the pan gasket is riveted to the pan from the factory to keep it in place during assembly. A small amount of grey sealer is applied to the front and rear covers where they meet the block.
Thank you!!
