LS2 with ls3 heads forged piston
But I'm at the point where I'm almost ready to install the engine for good and start it up. I have L92 823 heads that I installed some Brian Tooley springs into and I had Pat G spec a cam for the stock LS2 with those heads. I also have a forged lQ4 that I was building that already had the crank pinned and balanced.
I'm thinking about going through the ls2 fresh rods and bearings and using the crank and forged rods from the LQ4 and buying forged pistons with valve reliefs for the l92 heads so that I can run a better cam. This will be a street car, who makes a forged 4.005 piston that works with l92 heads?
Works with a 6.125 rod and stock stroke.
Summit has a pretty good deal on them at the moment. I had a my crank from an lq4 pinned and balanced for eagle rods and similar Mahle pistons in my lq4. After getting this crank balanced with the new pistons will I be able to use the lq4 crank in my LS2? The Ls2 is from an 06 gto so it has a 24x reluctor wheel
