Does this tt cam work NA?
LSA 116 + 5
intake @ .050 226 and .605 lift
exhaust @ .050 235 and .608 lift
Can i have this in i stock ls2 or do i loose hp? compare to stock cam?
I'd probably advance the cam a few degree if you have the piston-to-valve clearance. The IVC point on that cam appears to be pretty late (111 ICL), I'd try and advance it to a 106 or 108 ICL to help out your bottom end torque.
Cole
I'd run it if it was all I had.....particularly in a heavy car like my Impala.
It will also idle as smooth hell.....barely a hint of lope.
KW
