6.0 BTR stage 4 tight PTV
sbe L77 6.0
melling pump
rollmaster chain
ls3 heads
comp trunnions
BTR stage 4 kit 233/250 .618 .596
johnson lifters
super victor
edelbrock 4 barrell
holley hp efi
Originally installed the cam dot to dot. Sure enough cam was 2* advanced. Degreed the cam in spot on once retarded 2* on the rollmaster lower sprocket. Set tdc using the piston stop method. Cam is degreed at 8* btdc at 0.50" as per cam card. Lift measured with dial indiactor directly onto lifter.
Installed checker springs, made a solid lifter, old gasket, torqued head down, comp adjustsble pushrod used to set zero lash. Dial indicator directly on spring retainer measuirng lift then pushing rocker by hand to check ptv making sure dial indicator returns to where it was previous.
Ptv numbers come back as follows:
Intake - Exhaust -
8* .120 340* .107
tdc .053 345* .082
5* .032 348* .074
8* .025 350* .069
10* .025 353* .068
12* .027 355* .072
15* .037 358* .082
20* .063 tdc .092
Intake 0.025"
Exhaust 0.068"
These seem extremely tight. I know this cam is tight. But looking for opinions on if this is ok or not? Im awaiting an email from Brian but he must be away atm. Any guidance much appreciated.
Cheers - Brad
FYI
Retarding the cam will give you MORE intake clearance and LESS exhaust clearance
Advancing the cam will give you LESS intake clearance and MORE exhaust clearance
Looks like you will need to put some valve reliefs in the pistons.
Cole
You can also do it by using adhesive backed 60-80 grit sandpaper on the face of the valve and cut to the OD size of the valve.
Get creative, but be sure to watch your depth of cut when you do it.
Cole
i will relief the pistons.
what clearances should i aim for?
.060 intake and .100 exhaust? What about radial clerance? .030+?
Nows the time to mill my heads is .025 off worth the extra bump on compression? Or should i just go with a thiner headgasket for now?
Is it worth checking quench and seeing if its possible to squeeze it a little tighter? Or not much gain? Whats standard clerance?
is there much gain left on the table not going tighter?
Flycutting the pistons or going with a different cam are much better solutions.
KW
i will go with a .040 gasket and mill .025 off the heads. Which gives me about a 64cc chamber?
According to a compression ratio calculator that puts me at 11.1 to 1? (4" bore, 3.62" stroke, 64cc, .007 deck height, .040 gasket, 4.030 gasket diameter) does this sound right?
then i had .025 and .068 ptv with .051 gasket. So .025 mill and .011 thiner gasket id be at -.011 and +.032 ptv clerance. So if i cut .050 and .060 into the pistons ill have about .040 and .090 ptv. Does this sound right/enough? I will check ptv after cutting of course.
will -.035 (thinner gasket+mill) mess with my supervic manifold fitment?
-sorry for the essay, first time doing this having someoe double check my calculations would be great! Cheers brad
Once you get the first intake and exhaust cut, you can use a "drill stop" on the stem of the valve to set your depth for the other cylinders. But, be careful if the valve guide heights, valve installed height, etc. aren't all even across all cylinders, your cut depths will vary. Maybe measure from the top of the guide to the tip of the valve (use same valve for all cylinders) to see how close you might be before you cut any.
.035" total change in deck height should affect manifold fitment.
Heads assembled and torqued down with arp bolts, oil pump and dampner/chain all final insalled.
Next is measure pushrod lengt, which i may need some opinions on what preload/length fits best.
And build a set of headers. Currently have 1 3/4 4-1s. Obviously i want minimun 1-7/8s. Whats opinions on 2"? I figure if im building a set why not the bigger and to allow for future bigger cubes? Or will the 2" only loose midrange on this motor?
Be sure to polish/deburr/round the edges of the relief cuts in the piston though.
I think 1.875" tubes would be sufficient for a good "street" combo. 2.000" tubes are better suited for 400+ inches and/or LOTS of RPM.
cometic gaskets are torqued down. But alot of people are reusing them? If its ok too ill pull the heads and chamfer.
