speedmaster (Pro Comp) Ls7 6 bolt castings
I’m impressed with the ProComp units here, and I agree with you concerning lifters. Don’t skimp, especially with a race application.
Today’s hollow steel valve technology is incredible. I’d not go with titanium valves unless I was willing (and financially able) to change them regularly. Titanium has a short life span. This is why you see so many used sets for sale on race equipment sites.
This thread is full of great info.
Here's the length for GM Lsx CT valves: 6.350 vs a ls7 intake valve of 5.130 or so.
A thinner part of a combustion chamber will run hotter and can cause single cylinder detonation issues that baffled the HELL out of the “tunnel port” guys from Ron Niel’s Prototype Racing Engines back in the day,till Ol’ Smokey figured that **** out for them.
Sure those things have a great shape and runner size, prolly can flow like all get up, but in the real world, potential don’t mean squat
Quote from another thread:
You wanna hear a good joke....this is for the guys over on the other thread about Pro Comp Ls7 heads who know heads. Look at what a MAST Ls3 12 degree head did VS factory Ls3 heads. So funny. All or most Ls7 heads in the Ls7 heads test were within reason.
__________________
We baselined the engine with factory GM LS7 castings. Four of the heads we tested were stock castings that had been CNC-ported by GM Performance Parts, Lingenfelter Performance Engineering, Texas Speed, and Scoggin-Dickey Performance Center (SDPC). We also checked out the CNC-ported versions of the dedicated castings from Procomp Electronics, Mast Motorsports, and Texas Speed. All were run with appropriate valve springs and factory LS7 rocker arms. We verified that all had 70cc combustion chambers.
Conclusions
There wasn’t a dog in this bunch. There is a sizable gap in price between the most expensive and least expensive heads, but they all made big power. There was greater variance than what we saw in our LS3 test (where every head tested made virtually the same power), but in reviewing the numbers, we had to ask ourselves what the real difference in e.t. or seat-of-the-pants feel would be between the 13.5 average horsepower and 12.9 average torque numbers that separate the lowest-priced heads and the biggest-power heads we tested.
We were also interested to note that, in general, the heads with the better flow numbers produced better power, as you’d expect. But the flow bench does not tell the whole story; looking at flow alone, you might not select the SDPC heads, yet they outpowered some of the heads with similar or slightly higher flow numbers. There’s still some magic in port and chamber shapes.
Bottom Line:
Every LS7-based head is amazing. The Procomp heads clearly win the low-price contest, using import castings and domestic porting to make more power at a lower price than even the stock LS7 heads. Judging by the average power numbers, the Texas Speed PRC heads seem to offer the best value, and the Mast Black Label heads crank out the highest power.
GMPP 270ccc heads: peak Hp/tq 773 @ 6300 and 704 @ 4700
ProComp 265cc heads 785 @ 6400 and 716 @ 5100 needs some handy port work!!!!
Lingenfelter 275 ccheads 793 @ 6500 and 719 @ 5300
TSP/PRC 285cc heads 796 @ 6300 and 725 @ 5200
TSP GMPP 265cc heads 799 @ 6500 and 714 @ 5300
SDPC Ls7 heads 802 @ 6500 and 717 @ 5500
Mast 274 cc heads 810 @ 6600 and 726 @ 5300
http://www.hotrod.com/articles/hrdp-...top-ls7-heads/
1 interesting thing is I looked at Mast small bore Ls7 heads which I know is Correct for cfm and other things *also a better head, and not inflated #'s*. As well as TSP small bore with other Cnc programs. Even the ProComp casting in the same article. Here's what I read & learned cheap heads with a good porter have better under the curve cfm. To the young man who started the thread this confirms what I told you buy the heads Cnc'ed and work it to get low and mid lift #'s up = short side radius and bowls. Easier and quicker. If you read below I've looked a Mast 265 heads the runners is about the same with mine the bowls with the larger valve is what adds more CC.
Mine are 275cc / 265cc Pro Comp cnc and tested on a 4.125 bore vs 4.060 used
0.2000 165.2 158
0.3000 238.7 225
0.4000 300.6 301
0.5000 336.2 337
Side note as I've posted this before Brodix heads on basically the same 495 engine as these magazines are all tied together Super Chevy, Hot Rod, *Popular Hot Rodding old & gone but was the Best magazine published* along with GMHTP gone also.
STS BR7 273 heads from Brodix made 799 hp @ 6500 and 714 tq @ 5300. Work a cheap head and your there also LMAO!
http://www.superchevy.com/how-to/eng...ylinder-heads/
