temp Of my oil kinda on the high need help
Old Jan 27, 2018 | 09:50 AM
hataw's Avatar
Default temp Of my oil kinda on the high need help
I have a ls3 motor with a tr6060 doing around 480hp on the wheel with mods I use the engine on a drift car here is my problem
My oil temp on heavy driving goes up to 250deg have a oil cooler but nothing else on the line should I put a thermostat or something also should I use a specific oil cooler am ok changing my oil cooler for a better one it’s a 25 row oil cooler on now with no fan
Water temp is fine does not go up runs on a good temp
Need info on what’s a good set up to cool my engine oil
Also am running a transmission oil cooler with a external pump just checking if I should remove the external pump as I heard there is already a pump in the transmission is this correct not familiar my problem is when I turn the pump the gear box feels sticky or grind some gears but when it’s off no problem so should I just remove the external pump
Old Jan 27, 2018 | 03:29 PM
Dragls's Avatar
Check these coolers out, but be ready to pay for a good efficient one.
https://derale.com
Old Jan 27, 2018 | 05:48 PM
LLLosingit's Avatar
Why not run a fan on the cooler?
I only use the internal pump on TR6060, Not sure what you would need any more than that.
