LS3 oil pressure/priming question
Old Feb 2, 2018 | 12:32 PM
Gasoholic's Avatar
Default LS3 oil pressure/priming question
Getting ready to fire up a new motor for first time.
Currently waiting for a few parts before I can crank it over. Parts are supposed to be here tuesday so next weekend possibly ready to fire it up. Possibly...
In any rate I primed the filter, cooler, and block and got good pressure. When I was priming it I made sure to rotate the crank a few times.
Question is,
should I prime it again before I fire it up? Or would it be okay if I put the alt and belt drive together now, and next weekend after I my parts get here just install them and fire it up?
I'm quite certain I've got oil all the way through the engine.
Old Feb 2, 2018 | 12:48 PM
LLLosingit's Avatar
Since it was already primed you could just fire it up and it should build pressure right away.
If you want a little added insurance to make sure the oil pump is working before starting, You could pull the spark plugs and turn it over until you see pressure, It will turn over easier/faster than if you left the plugs in. Last one I did only took a few seconds to see pressure and that was without pressure priming it first.
Old Feb 2, 2018 | 04:25 PM
Jimbo1367's Avatar
You said "primed" did you get oil out of ALL the rockers? If not, continue top prime IMO. Why not when its a NEW MOTOR.
Old Feb 2, 2018 | 08:37 PM
ChopperDoc's Avatar
Pull the plugs, and your fuel pump fuse. Turn it over about 50 revs. Should be gtg after that. .
Old Feb 3, 2018 | 08:29 AM
Gasoholic's Avatar
Thanks,
I have oil through out the motor. I verified.
