cam sensor help
The gen4 blocks have the front cam sensor, grey 58 tooth crank sensor, and the knock sensors on the side of block.
Does yours have the oil psi sensor built into the valley cover? Do u have the infamous dod looking valley cover? Are u sure the rear hole behind intake where the gen3 cam sensor is located, isnt the dod sensor?
