5.3 gen 4 rotating assembly
Old Apr 15, 2018 | 05:54 PM
Hillbillyracing's Avatar
Default 5.3 gen 4 rotating assembly
My engine is at the machine shop now, expecting them to tell me that they had to go .020 over.
If this is the case do I/should I have it balanced with the new .020 pistons? Thanks .
Old Apr 15, 2018 | 06:57 PM
KCS's Avatar
KCS
Moderator
Yes, have it balanced unless they can show the new oversized pistons are not too much heavier.
Old Apr 16, 2018 | 02:04 PM
ColeGTO's Avatar
Unless you are putting the SAME brand, material type, wrist pin size/length, etc. pistons in, a re-balance is almost a certainty. Even then, the bobweight should always be checked at least.
If it's close enough for your taste and you don't have to spin it, then you're that much further ahead in time and cost.
