Killed a brand new LS7 lifter?
At first startup, all sounded good, then I got a horrible knock (like a bad lifter - very loud). I checked preload, everything seemed good.
I took the car for a very short drive (just around the block), and the noise suddenly stopped, but it sounded like I lost a cylinder at the same time.
I took the valve cover off, and noticed that one of my lifters appears collapsed, and the pushrod isnt even touching the rocker. But the engine is much quieter!?!
What could cause this to happen, and so quickly after a swap? Car has practically not even been driven...
Is there any chance of getting the "collapsed" lifter back to life? I thought that they had a spring, which should push it back up even without oil, but I don't have lots of experience with LS engines.
I can’t see why you would have kept running the engine, or even thought of going around the block in it with it making noise.
I’d pull the head and take a look at that lifter and corresponding lobe. Go ahead and cut your oil filter apart and inspect as well.
