Summit Pro LS Cams
Old Sep 21, 2018 | 10:09 AM
  #41
MY_2K_Z's Avatar
Originally Posted by Patron
lil buddy I just got away with weapon charges I'm WAY past the 3 strikes law ....I gotta stay sober. 7 months and counting.
Damn your a badass,... idiot
Old Sep 21, 2018 | 10:52 AM
  #42
Originally Posted by JoeNova
You're not proving anything here. You are rambling and making yourself look bad.
Patron does a LOT of that....
Old Sep 21, 2018 | 12:45 PM
  #43
Summitracing's Avatar
LS1Tech Sponsor
Originally Posted by Dride76
Maybe.... A discount on camshafts fro ls1tech members for a short time
Ok Dride76!
All Summit Branded parts are on sale at 15% off! This includes the Pro LS Cams and other assorted go-fast parts that start with the prefix SUM- or SME-. https://www.summitracing.com/savemore?ibanner=HP50R825 has the details with the Promo Code "SAVEMORE"
Attached is the list of cams and the valvetrain parts that qualify. If you want them, come and get them because this sale isn't going to last long.
File Type: pdf
File Type: pdf
__________________
800-230-3030
www.SummitRacing.com
Old Sep 21, 2018 | 06:29 PM
  #44
Dride76's Avatar
Originally Posted by Summitracing
Ok Dride76!
THANK YOU guys!!!
Old Sep 23, 2018 | 09:43 PM
  #45
Bazman's Avatar
That turbo cam looks perfect for most guys running a single. What about us guys running twins on an LS3? I run small twin billet Bulls Eye with Batmowheel turbines - 62/67 in small SVO housings but they can flow enough for 1300hp if I wound the boost up. Much less back pressure than my old STS single. If I was looking for maximum power from 3000 to 7000rpm with peak at 6300, and I was willing to give my tuner 3 days solid tuning - esp part throttle tuning etc to ensure there was no stumbling or bucking - what do you think would work best on a blueprinted forged LS3 stock cubes, stock heads/intake? It has to be reliable as road raced and will see up to 5000 miles a year in and between events therefore need stable valvatrain and endurance springs like PSI etc, will likely spring for Ti intake and Iconel exhaust valves and refresh the heads, will drop cr from 11.2 down to 10.5 which will hurt low end, but need more safety. Tight quench, will be low 30's.
Old Sep 23, 2018 | 09:53 PM
  #46
qweedqwag's Avatar
Bought a cam from Summit in Texas for a turbo truck build. will report back when we get dyno numbers and running quality.
Old Sep 24, 2018 | 10:53 AM
  #47
LS1Tech Sponsor
We have some other offerings coming down the pike that we think you will really like! The valve events and strategy are unique and we'll be able to comment more upon them by Oct. 10.
__________________
800-230-3030
Old Sep 24, 2018 | 02:26 PM
  #48
Bazman's Avatar
Old May 9, 2019 | 08:37 PM
  #49
slogo's Avatar
I like that these cams are Manufactured in the good ole USA, have read and heard many people are very happy with the quality and
power they make, what is the best way to get advice on which cam would be a good match for my setup? is there a tech line at summit?
Old May 10, 2019 | 07:44 AM
  #50
LS1Tech Sponsor
Sure, we have a techline or we can assist you here or through a PM. Just basically need to hear your combination and what you're looking for!
__________________
800-230-3030
Old Aug 8, 2019 | 11:13 AM
  #51
stockA4's Avatar
Summit had the perfect grind I needed. I deliver pizza part-time with my LS1 powered camaro. I have gotten tired of knocking on people's doors all the time when I deliver pie so I installed the summit racing 8714 and Bingo! I don't have to knock anymore!
