Stock ls3 cam in LC9 for moderate boost?
Hey guys, couple quick questions regarding an LC9 motor I'm picking up this week. It has a failed DOD/AFM lifter, which I assume has wiped out the came lobe as well. I have a stock LS3 cam/Springs/Pushrods, Seats, etc from when I did a cam swap on my 2014 Camaro.
Just wondering if anyone has used the stock LS3 cam in a gen4 5.3, and what the results are? I anticipate they would be very similar to an LS6 cam?
Stock LS3 cam specs are:
204/211
.551/.525
117LSA
I am planning to Turbo this motor; I assume stock ls3 valve springs will be fine with moderate boost levels (15 ish psi)?
I am on the fence with gapping the rings; Any idea where they come in at stock?
Thanks
204/211
.551/.525
117LSA
Thanks
Thanks
Not mine.
If I were gonna upgrade springs with a stock LS3 cam, I'd go with these --->> https://www.racingsprings.com/index..../category/408/
PAC-1202 duel valve springs.
KW
KW
Not mine.
KW
KW
or is it a case where they are marginal in both applications?
