6.0 build
2. What is your budget?
3. Do you already have an aftermarket (performance) air intake and exhaust?
4. if need be.....are you willing to port the heads a bit?
KW
2- GET YOURSELF SOME PORTED 243 HEADS OR TRICKFLOW 225s
3- FAST 102/92 INTAKE AND TBODY
4 - 1 7/8 HEADERS AND TRUE DUALS
5- UPGRADE FUEL SYSTEM - INJECTORS, FUEL PUMP
6- ALL THE NORMAL BOLT ON CRAP
7- CIRCLE D 36-3800 CONVERTER http://www.circledspecialties.com/gm
8- TUNE FOR E85 - SPEED DENSITY CONVERSION
AS FAR AS CAMSHAFT GOES, TALK TO THE PROS, TELL THEM YOUR SETUP AND HAVE THEM RECOMMEND A CAM FOR APPLICATION.
LOOK INTO A 9 INCH REAR DIFF WITH 3.90 GEARS, TALK TO LONNIE AT EXTREAM AUTOMATICS
FOR A 4L60 BUILD, SLICKS, YOUR DONE..
ADD A 100-200 NOS AND YOUR IN LOW 10S HIGH 9S.
My ol' truck motor beats 90K vetts all the time.
http://www.high-performance-engines....ine-p/hp93.htm
The ATK engine does have merit.....but that max-ed out build you proposed was a bit off the rails. LOL.
And Beets did state in pretty clear terms what he wanted. I’m jus’ sayin’…..
KW
KW
