Cammed LS3 Noise
Old Sep 24, 2018 | 01:13 PM
c_LoW29's Avatar
Default Cammed LS3 Noise
So I recently re cammed my Camaro due to a lifter failure, got lifters out before any of them failed. Currently has a BTR Stage 4 Cam. New double springs with .660 lift titanium retainers all new LS7 lifters and all new gaskets. I torqued all the rocker arms to 22ft on the bottom of the cam lobe as directed. Rotated motor and rechecked all the bolts. After warmed up I am getting a tapping noise that I cant track down to save my life. I have attached a link to the video on you tube with the sound. Running Amsoil 5w-30 oil in it as well.
https://youtu.be/_c4NqHsED30
Old Sep 24, 2018 | 01:14 PM
c_LoW29's Avatar
Rockers have trunions in them as well.
Old Sep 24, 2018 | 01:19 PM
All of them do, which conversion did you use? Bronze bushing or needle bearing?
Old Sep 24, 2018 | 01:21 PM
Check the accessory drive. Sounds like some thing rubbing somewhere.
Old Sep 24, 2018 | 01:50 PM
c_LoW29's Avatar
COMP cams whichever they make.
Old Sep 24, 2018 | 01:58 PM
Needle bearings. One thing you should know, there HAS been a problem with trunnions wearing due to being too soft. Not just Comp's, others who used the same trunnions have the same issue. Not saying your noise is caused by the trunnions, but if you have more than 5000 miles on them you might take one apart and inspect the trunnion itself. If you have the problem, the trunnion will be worn where the bearing rides on it. The cure is a bronze bushing kit from either Straub or CHE.
Old Sep 24, 2018 | 02:02 PM
c_LoW29's Avatar
Only thing that confuses me is the noise is noticed lower than valve cover. With hood open it doesn't sound like that under any of the valve covers
Old Sep 24, 2018 | 03:09 PM
8.Lug's Avatar
That’s not valvetrain noise, it’s too quick, unfortunately that sounds like rod knock.
Old Sep 24, 2018 | 03:43 PM
I thought I heard sort of a squeaking noise, thought maybe a dry rocker, but maybe not....
Old Sep 25, 2018 | 01:07 PM
c_LoW29's Avatar
Took a stethoscope to the valve covers yesterday and the noise didn't seem to be coming from there. Wouldn't a rocker with bad or failing bearings or wear make noise up top enough to notice with a stethoscope?
Old Sep 25, 2018 | 03:23 PM
ColeGTO's Avatar
Sounds kinda like an exhaust leak to me. I'd re-check all the exhaust bolts at the head and the collectors.
Old Oct 1, 2018 | 12:33 PM
c_LoW29's Avatar
bingo this is probabaly what wiped out last camshaft
Old Oct 1, 2018 | 12:34 PM
c_LoW29's Avatar
Old Oct 1, 2018 | 01:49 PM
Uh-ohhhhh…..
Old Oct 2, 2018 | 11:35 AM
Summitracing's Avatar
LS1Tech Sponsor
Sorry to see that. We have the bushing style kits...whatever you need to get it back together. P/N SME-K-141560 and the installation tool if you need it.
__________________
800-230-3030
www.SummitRacing.com
Old Oct 6, 2018 | 12:54 PM
c_LoW29's Avatar
Thanks. I ordered the bushing style summit kit and tool and changed everything out already. Valvetrain hasn't been this quiet in a while. And the tool yall sell makes the job super easy. Now to see how well the bushing style kit holds up
Old Oct 6, 2018 | 01:21 PM
History has proven that it will outperform the needle bearing style. You should be OK!
