Which cam sensor for ls2 conversion?
Old Oct 12, 2018 | 01:19 PM
blk00ss's Avatar
Default Which cam sensor for ls2 conversion?
I’m having issues with my car not firing on all cylinders. So I went to the Chevy dealership and got a LS2 Cam Sensor from a 06’ GTO. I tried it and it pops and backfires with that cam sensor. So it’s not the same sensor that I have now. I bought a ls2 conversion kit from TSP back in 07’ and it’s what I’m still using. Figure it couldn’t hurt to replace it. So anyways, simple question. What part number do I need from GM for a ls2 conversion in a f body.
Old Oct 21, 2018 | 08:33 AM
dreadpirateroberts's Avatar
doesn't seem like there's a difference for LS2's, they all use the same sensor from what i can look up. Some have a harness extension, but FWIW it should still be the same sensor design.
what are you using for engine control? does the engine have a 24x or 58x reluctor?
Old Oct 21, 2018 | 09:09 AM
Is it randomly dropping different cylinders, or is it the same cylinder sometimes/all the time?
