head skim
Old Dec 28, 2018 | 11:49 AM
charlie88's Avatar
Default head skim
i am in the process of rebuilding a ls3 376/525 and have skimmed the heads 20 thou to bring the compression ratio back to standard due to 4cc dished pistons, i am using the original cam lifters push rods and rockers with the trunion upgrade ,are the lifters and push rods still in tolerance or will i have to replace the push rods with shorter ones ?
Old Dec 28, 2018 | 11:54 AM
You will likely need shorter pushrods.
Old Dec 29, 2018 | 11:14 AM
zboy2012's Avatar
Get a pushrod length checker and measure it to make sure you don’t need to run a shorter pushrod.
