Cranks, no start. c6 corvette
Old Apr 9, 2019 | 02:15 PM
staticki's Avatar
Default Cranks, no start. c6 corvette
Greetings,
Hoping someone may be able to point me in the right direction. Just pulled a twin turbo kit and installed a YSI kit to cycle back the complexity and money pit that's my car.
I have everything installed, but I cant get the car to run (did before I took everything off and reinstalled).Car cranks and cranks without firing.
No codes being thrown from what I can see in hp tuners
I am getting fuel which I can verify by the gauge on my fore regulator (holds steady at 60 psi) and I pulled the plugs and do have fuel on the tips.
I verified spark with an ignition tester and getting consistent spark on all cylinders when cranking.
I changed the crank position sensor to a new one
Verified all grounds are good and mounted.
Next step is changing the cam position sensor, but the car should run even if this was damaged somehow. I was playing around with HP tuners and noticed my fans wouldn't turn on by going into the settings and turning Fan 1 on and setting the PWC to 90%. I have my fans hardwired, but can a faulty fan circuit lead to a no start?
Thoughts??
Crank log; https://drive.google.com/file/d/1OfO...avMf-AhWY/view
Old Apr 9, 2019 | 02:42 PM
HighAltitude's Avatar
Check all of you grounds as that can cause a no start. Car will start with bad cam sensor just crank longer. Have you changed anything involving VATs or is it disabled? Have you verified the injectors are plugged in correctly? Can you see a crank signal in HP tuners?
Old Apr 9, 2019 | 10:45 PM
brandon6.0's Avatar
Check vats, grounds, and crank/cam sensor counts while cranking with hptuners. Tht will rule out faulty cam sensor. It will not start with a bad cam sensor. It controls injector pulse.
Old Apr 9, 2019 | 11:45 PM
Not true. It WILL start once the ECM figures out where the engine is in the firing sequence, which the cam sensor helps to do, and that's all it does. It just takes longer to start without the cam sensor. It does not control the injector pulse. The ECM does that.
Old Apr 11, 2019 | 09:38 AM
staticki's Avatar
Can I turn off vats on a corvette? I dont show the option in HP Tuners.
Old Apr 22, 2019 | 09:25 AM
staticki's Avatar
I changed out the crank position sensor again just in case I received a dud as well as the cam position sensor. Unfortunately, still no dice.
Old Apr 24, 2019 | 01:23 PM
93Polo's Avatar
My C5 fired with the cam sensor disconnected and gave a check engine light. We missed the connection reinstalling the motor. Pulled the intake and reconnected the sensor, no check engine light.
