Blower cam in a NA LS3?
For use in a LS3 A6 corvette
headers and SS3600 converter
duration seems nice but concerned about the
cam centerline.
Although it will spin to around 7000rpm because of the late IVC and early EVO. This is also why your bottom end and mid range won't be that good.
The supercharger would take care of power in this rpm range. a 225/244 118LSA +4 would worker better with a wider power band and excellent top end.
Ideally those specs on a 113 LSA with 3 degrees of advance would certainly work better NA and have the power come on sooner and you would make more peak torque and hp.
I have used a blower camshaft before on an NA and didn't like it.
Throttle feel was just too soft.
in general you don’t see shelf cams ground like this for NA applications as they aren’t very sexy, and don’t set butt dyno records. A tight center cam, 112+4 will peak hard and fast, go rumpity rumpity, and give a much stronger shove in the midrange where most people drive.
